No longer able to find data
Reinstalled DAZ Studio. Now unable to use content on external drives (which worked previously)
Error states data files are missing. Have checked. Data files are there on the drive. Now I just get untextured grey boxes. Has anyone else seen this?
How can I fix this?
  • GordigGordig Posts: 10,652
    Have you set DS to recognize your external drives as content directories?
  • Yes. The drives and content show up, but when I try to use them, I get the above.
  • Richard HaseltineRichard Haseltine Posts: 109,024
    Where is the content and what are the content directory settings? it is possible to have the files nested too deep or too shallowly, at which they will show in the content pane but the asset files will not be found.
  • The content is on a seperate external drive.
    How do I access the content directory settings?
    They worked with the original installation and I haven't moved any of the files.
  • Thanks Robert.
    Your comment, while not answering my question (you needed further information), your question put me on the right path.
    Kudos, Dude.
