How I make the outfit looks like what I bought on my model?
foxyfoxfurriesfoxyfoxfurries Posts: 387
edited July 2021 in Daz Studio Discussion
Hey every one.
I buy a lot of outfits and all of them so press on the body like you see in the picture of my DAZ . How can I make it looks like the picture when I buy this outfit. looks more release on the body
Thanks =D
  • Richard HaseltineRichard Haseltine Posts: 108,591
    edited July 2021
    Dialing the breasts back down would help, the mesh is now self-intersecting which is going to limit what any bridging morph or Smoothing Modifier can handle. Still, it may be worth checking the shapes in the top to see if it has soemthing like a Bridge or Cleavage morph.
    Edit: I see this is the 3DS forum, if that is indeed where you are working you won't have access to the Smoothing Modifier anyway though 3DS may well have soem kind of smooth-and-collide feature of its own.
    I use Daz Studio yes , have more Daz software to use that may help me with this?
    I wa asking because this is in the 3DS Max forum - if it's in DS I will move it to the DS forum (or you can do it by editing the first post).
    In Daz studio you could try selecting the top, then go to Edit>Figure>Geometry>Add Smoothing Modifier (if it doesn't already have one - check for a Mesh Smoothing group in the Parameters pane)
    Sometimes its good when it doint but in this outfit it looks a little bit strange hehe , I will try to do it thanks =D
    I have this one
    670 x 508 - 286K
    In that case it already has a Smoothing Modofier. You could try turning up the iterations in the Mesh Smoothing group in the Parameters pane, but I think the shape of the figure is not going to allow very much improvement.
    Well it looks good like that to but I think better make the outfit a liitle bit loose and not that tight . xD
    So better put it like that?
    And about the mash things its easy to do ? you have maybe a Youtube video for this?
    Which bit are you wanting a video on?
  • UncannyValetUncannyValet Posts: 264
    this is still in the 3ds forums.
    There are all these morphs that come with that outfit.  Did you maybe try adjusting them?
    • Easygoing T-Shirt
      • All - Expand
      • Back - Expand
      • Breasts - Cleavage Depth
      • Breasts - Cleavage Width
      • Breasts - Expand
      • Breasts - Expand (Left)
      • Breasts - Expand (Right)
      • Breasts - Height (Lower)
      • Breasts - Height (Middle)
      • Breasts - Height (Upper)
      • Sides - Expand
      • Sides - Expand (Left)
      • Sides - Expand (Right)
      • Stomach - Center Height
      • Stomach - Expand
      • Waist - Expand
      • Waist - Expand (Left)
      • Waist - Expand (Right)
      • Shirt - Length
      • Undress - Both 01
      • Undress - Both 02
      • Undress - Both 03
      • Undress - Both 04
      • Undress - Both 05
      • Undress - Left 01
      • Undress - Left 02
      • Undress - Left 03
      • Undress - Right 01
      • Undress - Right 02
      • Undress - Right 03
    • Easygoing T-Shirt
      • All - Expand
      • Back - Expand
      • Breasts - Expand
      • Sides - Expand
      • Stomach - Expand
      • Waist - Expand
      • Shirt - Length
      • Undress - Both 01
      • Undress - Both 02
      • Undress - Both 03
      • Undress - Both 04
      • Undress - Both 05
      • Undress - Left 01
      • Undress - Left 02
      • Undress - Left 03
    Yes you can play with this pull the shirt up and all this stuff but dont have any option to not make it thight , I mean my girl have a little bit ABS and even I make it a little bit more large the abs seems still on the shirt hehe xD
    I wanted to make the shirt like the picture they show when you buy this , you think I can may do this or better stay with what I already have and leave it (I looks good like this to but a little bit strange) , Thank you!
    Moved to Daz Studio discussion.
    The Smoothing Modifier should help with the abs, but your figure has much bigger breasts than the one in the promo image and that is going to be a problem to accomodate (and lead to texture stretching). If you reallt want to have the cloth look plausible across the breasts you are probably going to have to create a morph in a modeller (Hexagon, Blender, or whatever you wish).
  • Silver DolphinSilver Dolphin Posts: 1,639
    Daz has a Blender bridge and it works reasonalbly well. That would be my suggestion as well. Hex is ok but too many bugs.
    There is this popular product: https://www.daz3d.com/sy-clothing-breast-helper-genesis-8-female
    However as Richard mentions, you would still have to dial the breasts down in size and/or reposition them away from each other so that their mesh does not intersect. The clothing is trying to fit on the mesh so if the mesh is running into itself, the clothing will too.
  • WSCWSC Posts: 157
    Another one you might look at is
    https://www.daz3d.com/fit-control-for-genesis-8-female-s
    I have an OC with a rather large chest and this works pretty good.
