render
konkon Posts: 389
I loaded a already ready to render scene by accident now every time I render it cuts my render in half. Why?
  • Miss BMiss B Posts: 3,071
    How did you "load" it. Did you "open" it from the File menu, or did you just find it in your render library and double-click the thumbnail? If you found the thumbnail in your library and double-clicked it, what you were doing, in essence, was merging that scene with the scene you currently had set up, in effect making it all one scene.
    If this is not what you did, then I'm afraid I don't know what would cause that to happen. The only thing I can think of is you have 2 separate scenes loaded and they're rendering funny. Maybe someone else will have better information for you.
  • konkon Posts: 389
    I load the dragon slayer scene. Then I went to file new and now every render doesn't render the whole window view. Its like the render zooms in.
  • kaotkblisskaotkbliss Posts: 2,918
    Are you selecting the camera you want to render from after you click on the render tab and before you start your render? Also, have you checked your render setting (the width and height more specifically) to make sure they are what you want?
  • konkon Posts: 389
    I don't use cameras. I will check the render settings thanks.
    Cameras are really the only way to save a specific view/angle in a scene if you close it then go work on another scene.
    The perspective view will always use the last view used (even in another scene).
  • konkon Posts: 389
    I move around and change things a lot I've never kept a render yet. Thanks for all the help i fixed it.
