Genesis 8.1 M&F Anatomical Elements?
2»
  • LeanaLeana Posts: 12,915
    ANGELREAPER1972 said:
    Leana said:
    nonesuch00 said:
    Leana said:
    fred9803 said:
    The Blurst of Times said:
    I've been attaching the Genesis 8 anatomical elements to Genesis 8.1. It's not a new prop, anyway. It's the same Genesis 8 prop.
    If you have morphs for the gens, then they still apply even though you're using Genesis 8.1.
    According to Richard mod the anatomical elements provided with the G8.1 bundles are not the same as the existing G8 ones. See attached link.
    What Richard said in that post is that the "G8.1 male elements for female" and the "G8 male elements" are different items, not that the anatomical elements provided with 8.1 are different from the ones provided with 8.
    They are the same, and if you own a G8 pro bundle you'll get the update with the version for the opposite figure even if you don't buy the 8.1 bundles.
    I wonder why they went to all the trouble of creating male anatomical elements for the female and female anatomical elements for the male but didn't include the morphs masculinizing the G8.1F and feminizing the G8.1M. It seems sort of incomplete work not to have done so. Of course the result might then be villianized as an 'unrealistic ideal Barbie and Ken' since then all the G8M / G8F body type morphs couldn't be applied to the opposite gender in any case.
    There are transgender shapes available in the store: https://www.daz3d.com/transgender-shapes-for-genesis-8
    just don't upload renders featuring them on this site as it goes against the TOS here, found that out the hard way no pun, ended up returning this for a refund because of that and it was tactfully revealed to me from several differant departments here
    I don’t know why that render was removed, but just using those shapes should not be enough
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,595
    bought it it help enhance more accurately characters but didn't get to use it before returning due to responses got from several different areas over my previous attempts nothing revealing or negative in my renders btw but because there are some out their that don't agree with that lifestyle so didn't want to offend them - like many other products ok to sell just not post renders using certain products, had a few interesting reactions on other sites
  • Richard HaseltineRichard Haseltine Posts: 109,129
    As leana says, there is no issue in using the transgender morphs in geenral. if you have questions about specific image or post removals you need to contact the gallery team (by replying to their note on your unpublished image) or the forum team (by replying to their email).
    got neither -  images were wiped from existance completely in fact no notifications at all, and yes looked in the edit section not there either some other are which don'tmake sense either but yeah got hinted at reason from another department so returned that product because of hints would've given me better shaping options but I gave up on the theme though there are still two related still up
  • Josh P.Josh P. Posts: 49
    Richard Haseltine said:
    Make a UV mapping, or select which UV set to use?
    Before, one could transfer the torso material to the G8F anatomical elements using Zev0's Skin Builder for GF8.
    It's been made abundantly clear that this tool will not be updated for G81F.
    However, is there currently any tool which would allow the user to assign the G81F Body surface to the G8F anatomical element, and get the correct UV so it will display properly?
    Thanks in advance!
