Physics in Carrara 8.5
RodB2RodB2 Posts: 19
Hi Guys. This is my first post here. Can anyone tell me where the "simulate physics tool" is in 8.5. I have no problem with this in C8. See attached screen shots
    Hmmm.... Do you have Carrara standard or Pro? I'm noticing some other missing icons as well.
    edited September 2014
    The reason I ask if you have the Pro version is because of the missing icons in my screen shorts. I have C7.2 Pro, so they may have been moved, but I doubt it from screen shots that have been posted by users of C8.5 Pro. The icon to run a physics simulation is the one on the far left. The others are for modeling in the Assembly room (center right) and the 3D paint tool (far right). I believe those are all Pro features.
    153 x 69 - 12K
    1028 x 813 - 189K
  • RodB2RodB2 Posts: 19
    Thanks for your reply, EP. All indications are that I do or should have C8.5 PRO. I paid for PRO, I have a 8.5PRO icon on my desktop, the splash screen indicates PRO version and my serial# seems to be the PRO version.
    Well, either the controls were moved or the little menu became un-docked somehow. Can you reset the application's default display?
  • Bunyip02Bunyip02 Posts: 9,261
    Hello RodB2 & EP
    I have 8.5 Pro and my Icons are in the same position as EP (ICON highlighted in yellow courtesy Paint.NET)
    Looks like the 4 icons that should be in that area are missing in action !!!!!
    Is your computer 32 bit or 64 bit ?
    There seems to be a few comments about that elsewhere.
    Regards Bunyip
    EDIT (Forgot to also point out that I have Inagoni's plugins so there are a few extra icons in the main section that you might not have as whats shown on my screenshot - still got to learn how to use everything !!!!!!!)
    1237 x 739 - 164K
    Post edited by Bunyip02 on
  • DUDUDUDU Posts: 1,945
    Right clic on a free space of the toolbar and check everything...
  • rk66rk66 Posts: 449
    Hi,
    for Carrara 8, but possibly a little help.
    http://carraracafe.com/downloads/?did=32
    rk.
    DUDU_00001, problem solved. I didn't have 3D tools selected. Don't remember deselecting them though.
    Hi RodB2,
    glad you got it to work.
