How do I install an OBJ into DAZ4 with textures? [Scifi Floating City]
JoltrastJoltrast Posts: 208
edited July 2021 in Daz Studio Discussion
I have a zip file and inside is some maps in .jpg format an .mtl and an .obj
The first two lines of the .obj read
# Exported from DAZ Studio 3.1 mtllib Scifi_Floating_City.mtl
I have no idea quite how and where to install these files. Would they go in "Props"? Does it matter where they go?
I know I need to alter the .obj to point to the .mtl but I'm not sure what to put so it references the correct path.
Thanks in advance!
Post edited by Joltrast on
  • Richard HaseltineRichard Haseltine Posts: 111,420
    You can use File>Import to load them from anywhere.
  • JoltrastJoltrast Posts: 208
    edited July 2021
    Not only did that work, but it also loaded the textures without additional work. I just need to create a new folder in Daz now so that I can keep everything together. Thanks!
