Wet Body Geometry Shells
Hi!
I bought "Wet Body Geometry Shells" of vendor SimonWM!
Seem to be extremely heavy when applied to a character!
I wan´t to turn them off but can´t find any actions or settings for this!
If anyone knows how to turn the "Wet Body Geometry Shells" or any other texture add on such as the "Tattoo Parlor Geneis 2 and V6 Vol1" which is a real heavy map configuration as well.
I also wanna know how to bake shaders since the system inside DAZ isn´t easy to cope with! In other words a little bit strange to me!
P.S. I find it very frustrating that there are no easy ways through DAZ to contact a vendor directly and ask him or her of a tiny problem like this!
You can PM them here in the forums. For SimonWM, that is his forum name, so you can search for that and when you find his name, click on it and it will take you to their member page where you choose to PM him.
Hi Jaxtone,
Geometry shells in DAZ Studio you turn them off in the Scene Tab by clicking on the eye icon. You can also delete them from the scene if you decide you don't want to use a particular effect.
There is a way to consolidate multiple geometry shells effects into one single geometry shell and the product illustrated PDF guides you step by step. If you do so you loose the ability of sliding each drop across the 3D geometry.
To bake LIE effects like Tattoo Parlor you will need to capture the temporary diffuse and specular PNG maps DAZ Studio creates while still open, save those files and apply them.
Layered images, are usually combined in C:\Users\Your computer name\AppData\Roaming\DAZ 3D\Studio4\temp as one layer png temp file. DAZ Studio will flatten all the layers with the skin uv map for each surface. As soon as you close your scenes these temp files are erased.
The PDF in the pack is FUBAR- i tried to dl it twice and the ReadMe pdf will not open. Advice/link?
The installer was recently updated. It is possible it may have been corrupted. I will install the product in a computer without it and report back.
OK, I installed the product thru DIM. The PDF installs perfectly fine in my computer.
Alternatively the PDF is linked to the readme file. Here's the link:
http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/19806/19806_wetbodygeometryshells.pdf
Via the product readme on the wiki:
Very cool- thanks.
Correct. Thank you.
