Morph to remove nails
Is there a morph to remove G8M fingernails?
Doing a torture scene? lol. If you actually mean remove and not like shorten, you should be able to just turn the surface invisible with opacity I think.
They are holes apparently.
i want to retexture an arm without nails so i need the surface to paint on.
Wow lol..... Didn't see that coming.
Are you sure everything has been zeroed out? I've only done it with Genesis 1 in 3Delight, but there may be a specular element that's still active
I just tried with zeroing out everything (setting the limits of refraction to 0) - and unfortunately, yes, there are holes.
what about a morph to smooth nails?
https://www.daz3d.com/no-suit-for-genesis-8-females
like gloves? try that
...or do you want realistic fingers without nails?
Ah thanks, i will try that.
