powerpose Genesis 8.1 works worse than genesis 8
hi guys, just to put it out there. In case you guys hast notice.
I work a lot with power pose because you can  move the whole spine of the body, or the neck, in a uniform and natural way, using the dots with lines (like a sun)
It was one of the features I was very excited about genesis 8.   The articulation points in the power pose. in body and in the face.
Now with the presentation of genesis 8.1 everything looks amazing.  Except for Power pose.   It is the same as genesis 3. with a lot less articulation points. here is a comparation.
Victoria 8( 33ponts of movement on body, and 18 on face)
 Victoria 8.1 (22 movement points of body and 6 on face)
As you can see, there is a much better range of movement on the previous model with power pose.
My question is, why going back to basics if we had something better?  Don’t the new products are supposed to be better? Not taking useful features out?
why do you guys think?   Do you use power pose? are you equally frustrated with this as me?  Let me know what you think. I also attach some images.
  • IamPerttiAIamPerttiA Posts: 25
    Template set for the 8.1 body = Default (Generic)... You are not showing what it says for the head.
    Ok, sorry. I already checked. It says the same: Generic.  The thing is, you cant change it. It has no other option than generic. So the answer is that Genesis 8.1 did not come with a powerpose template.
