Looking for water props
Hi there,
Are there any props available that could be used as water when it comes out of a fosset or when it hits the ground?
I know there are water materials out there that can be applied as a second layer to a texture, but what I'm after is a seperate prop (or even better, morphable figure) to simulate splahes and running water.
If you know of any, please feel free to post them here.
Thanks a thousand,
Me
http://www.daz3d.com/rigged-water
Wow, that looks realy good!
The only thing it's missing is a real splash effect (when it realy HITS the ground ( and has a bit of a rebounce ) see pic below:
There is a free set that are just OBJ, at share CG, By Spacebones. I will see if I can find you a link
Oh that was easy http://www.sharecg.com/v/25522/view/5/3D-Model/Liquid
Oh that was easy http://www.sharecg.com/v/25522/view/5/3D-Model/LiquidSickleYield also made Daz 4.5 props from thise object files (with Spacebones' permission) and created liquid shader presets for them as well here.
If you use DS 4.6+ then this pack can help: http://www.daz3d.com/liquid-pack
those are great!
