Question about installing 32 bit and 64 bit versions
I'm having problems with making NLA clips on my Windows 7 64 bit system with C8.1 Pro and C8.5 beta both for 64 bits.
Is there any problem with also installing the 32 bit copies of these in separate folders to see if the problem is with 64 bit versions?
Thanks
should be just fine . . . be sure 32 bit program is in x86 programs location (not 64 bit location even with different named folder)
ok - thanks - will install 32 bit versions and see if NLA works in those
