Iray on AMD cards
2»
  • edited June 2021
    So the reason my PC gets all wonky during my renders is because Iray forces into the CPU due to having AMD? Well, that is a show-stopper for me because it messes up my PC. I want an alternative to Iray that does support my AMD GPU, because otherwise I can literally not use my PC to render.
    Post edited by Chohole on
  • TheKDTheKD Posts: 2,711
    Problem is, Iray is a render engine made by nvidia. That is why it only works on nvidia cards.
  • nicsttnicstt Posts: 11,715
    Use Blender and cycles; you can use either card there.
    I also found cycles to be much better using the CPU than nvidia.
  • Richard HaseltineRichard Haseltine Posts: 108,949
    The Advanced tab of render Settings does allow you to tell Iray to use only a limitied number of available threads, which should stop it from locking the system even with Iray.
  • nonesuch00nonesuch00 Posts: 18,795
    In the iRay setting go and
    1) Optimize for Memory
    2) CPU affity change it to only about 1/2 the CPU cores you have available.
    Your PC will still crawl on some renders until DAZ Studio/iRay finish building the renderable scene from your DAZ scene but once it starts rendering (usually less than 5 minutes, certainly less than 10 minutes, for 99% of the scenes you'd make) you can use your PC still. The render will still take 4 - 48 hours to render to 2000 iterations at FHD but that's been true of rendering without a specialized GPU that the render engine was built for from the beginning of ray tracing.
  • TBorNotTBorNot Posts: 375
    Proprietary:  something that is used, produced, or marketed under exclusive legal right of the inventor or maker specifically.  See iRay.
