why the parenting of clothing?
WendyLuvsCatzWendyLuvsCatz Posts: 40,215
a lot of G2F and G2M clothes loads parented
I HAVE to unparent it for both FBX export to iClone or saving a duf scene for Carrara or I get rigging issues
am wondering why this is a default and what advantage is in it?
  • XoechZXoechZ Posts: 1,102
    I also do not understand it. Maybe a "cleaner" scene tab with less items? I don´t know. But I also do not like this behaviour. It happens with some hair styles too, and I guess it is done by the vendor who decides to load it as parented.
    First thing I always do, after loading such items, is to unparent them.
  • DogzDogz Posts: 912
    edited September 2014
    Yeah its bit annoying when you just loaded up a garment and first thing you want to do is select it to change mat or tweak its morphs. And you find you self drilling down the heirachy, but yes, i guess it less cluttered. I'm not actually sure if I'm guilty of this sin or not. I think when you save out a Prop/figure asset the parenting data is a default setting that you have to manually uncheck if you dont want it..
    You know what annoys me more though? Pose presets that re-position the character back to 0 X,Y,Z translate and or re-scales them back to 100%, arrrggghhh... no! why? ! :D Again, that's save defaults in action.
    Post edited by Dogz on
  • GuyBcapsGuyBcaps Posts: 36
    Oh yeah. These are the worst. Heck, the Poses that came with the base V6 model do this. WTF?!
    Resetting facial expressions. Also obnoxious! I know some poses have built in expressions. But can't you include them as a separate head pose file?
    Ah crap - now that one I AM guilty of, But It was my first pose set ever and and....(Insert lame excuse)
    No, seriously you are quite right, the expressions should be saved out separately.
  • Richard HaseltineRichard Haseltine Posts: 108,412
    Having the clothes parented to the figure is necessary for wearables and hierarchical pose/materials presets to work.
    Yup. This.
    But on the poses thing, remember - you can use Ctrl+click on a pose and uncheck the translations to keep from resetting its position!
    Yup. This.
    Woah, never knew about that little gem, thank from here to eternity sickle :) !
  • FistyFisty Posts: 3,416
    Parented clothes drive me absolutely nuts.. I never do it, but was forced to by QA at one point. >.<</p>
  • Tramp GraphicsTramp Graphics Posts: 2,422
    I don't even know what heirarchial pose/material presets are, but I never parent my conforming clothes to my Genesis figures, and the clothes follow the figures' poses just fine.
    edited October 2014
    Cant say I've noticed what difference it makes either, but if Richard (backed by Sickle) say so, I ain't gonna argue. :P.
    Probably I've never needed to do what ever the fudge it is that needs it.
    In my case, wearables presets. Any time I do an outfit I usually offer it with a preset that loads the entire outfit, and proper setup for those requires things to be parented. I do this with my rope/chain prop type things too.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,215
    I admit I did find one senario where I needed to do it,
    instancing
    but with that came a catch, transforms added to aniblocks do not work on instances, they move in place
    they do however save on resources in octane render if I ever need identical crowds doing the same movements.
  • fixmypcmikefixmypcmike Posts: 19,696
    instancing
    Music vids? Line dancing?
