Clearing timeline
thoromyr
Working on a scene, I am trying to remove all the animation for an object. That is, anything set in the timeline after frame 0. I have a fenric plugin that appears in the menu as Clear Timeline. When I run it the timeline blanks out, until I collapse and re-expand the tree.
Anyone know how to use this plugin? For reference, I'm using C8.5 on OS X 10.9.
I have that plugin too.
It appears to only work with characters - let me qualify that - it supposed to work with characters only, however like you I didn't get a result so more experimentation needed or perhaps read the instructions LOL.
With simple object in the scene the fenric keyframe delete is greyed out.
If I'm dealing with an "object" I can usually quickly lassoo the the keyframes and press delete but as you know you have to get ALL the frames.
The other way ( I think ) is to convert to "master Clip" which clears the timeline and saves as a clip so you then have to delete the clip.
hey, thanks! I'll have to try the master clip trick.
