Portrait - Basic Lights Auto Set up [Commercial]
13»
  • ArtiniArtini Posts: 10,557
    MikeD said:
    Update Ver 1.1 is now released.
    Updates History
    Version 1.1 June 2021
    - The script is now correctly saving and reading the config file. The config file will be saved only if you use the "Ok" button of the dialog. The "Close" button does not save the config file.
    - The priority is (existing lights set up) > (config file settings).
    - The 3D vieport is now returning to the "Cube View Controls" after the luminous calculations, if the "Cube View Controls" was initially selected.
    - The default value of the "target lightness" for the main light is now 134 instead of the original value of 175 which produced overexposed images.
    - A "Restore Default Values" button is added to the bottom of the dialog window to get all the values back to the default ones.
    Rememeber you can always change the target lightness of the main light to your desirable value, if the 134 is not good for you.
    Thanks for your patience!
    - Mike
    Thank you very much for the update. All the best for you.
  • MikeDMikeD Posts: 317
    Artini said:
    Updates History
    - Mike
    Thank you Artini!!
  • veenveen Posts: 140
    great to see the update is available! thank you.
