Reality Plugin Render Image Composition
davegraham04davegraham04 Posts: 0
I am rendering an image using the Reality plugin and I am wondering if I can do so in a widescreen format rather than... tallscreen (???).
My image keeps rendering taller and I'd rather it be wider. You know what I mean. When I move the FrameSize bar on the output tab, it only allows me to choose "tall" options.
Can I render widescreen images? Thanks.
    The only thing that 'frame size' will do is change the scale of the output image. You need to edit your render settings outside of the Reality window to set the resolution of the final image.
  • davegraham04davegraham04 Posts: 0
    How do I do that? Where am I looking for these settings at?
    Thanks.
    Inside DAZ Studio, go to Render > Render Settings, and select the Preset that you want.
    There are loads of them, including widescreen in various formats.
