Filter Forge 10 Pro
RAMWolffRAMWolff Posts: 10,359
So I just purchased this through the portal here as the only upgrade path from 8 to 110 for me was a lifetime price of $150.00 (my discount for owning a previous version) so like many money is tight so that wasn't going to work for me. SO I purchased through here.  Not sure what's going to happen now.  Does the makers of the software then send me my license and download link?  Not showing up in my Product Library and no code in the Serial Numbers area.  Just need some info on this.
Thanks so much
Richard
«1
  • MaARiTtiMaARiTti Posts: 45
    You should download it from filter Forge's own website and wait for the email. They'll send you license numbers, so I guess ?!
  • BradCarstenBradCarsten Posts: 856
    Mine was under serial numbers. May need to get hold of the help desk if it doesn't come through.
  • Charlie JudgeCharlie Judge Posts: 13,303
    Previous versions of filter forge that I have purchased through DAZ show up in my product library with manual download and the serial number is in my serial numbers. So, you may have to contact DAZ customer service
  • AscaniaAscania Posts: 1,855
    Purchased it, found the serial in my account but no available download. If they expect us to download the actual program from an external site that information should really be communicated, together with a proper link.
  • barbultbarbult Posts: 26,380
    The Daz product web page says
    • DazCentral Manual Install
    Is that not true then????
  • McGyverMcGyver Posts: 7,085
    edited June 2021
    I've only ever purchased Filter Forge from their website, but if I recall correctly from previous questions like this, I'm pretty sure Charlie Judge and Ascania are right.
    I'm going to make a mention of this at FF's forums, they are usually pretty good at addressing stuff like that, maybe they'll add info that will make this procedure clearer... They have actually taken my suggestions seriously in the past and edited confusing statements in their sales or website info... unlike a certain website we all love which often lets confusing information remain indefinitely.
    On a side note, I probably use Filter Forge more than DS, so for me the lifetime upgrade was worth it, even though I only upgraded at a big discount (70%-80%)...
    Enjoy FF 10, some of the new features are pretty cool, especially if you make your own filters.
    Post edited by McGyver on
    I just purchased ,Filter Forge 10 Pro, and mine was under serial numbers too and manual download was in my Order Information not in Product Library.
    Naw, the download link in the order just takes you to your library. Where the download isn't.
    1031 x 632 - 252K
    Well, I posted a comment about this at FF's website, hopefully I'll get a response or someone will amend the info on the store's product page to make this clearer.
    edited June 2021
    OK! then it must be downloaded from Filter Forge
    Post edited by MaARiTti on
  • Richard HaseltineRichard Haseltine Posts: 108,617
    Everything seems to say that, hence all the confusion when downloads were often missing and people thought it was a ploy to make them use Central.
    I will ask about downloads.
    Thanks, Richard. I got a serial number OK, so it is just the download that needs to be resolved.
  • RCTSpankyRCTSpanky Posts: 850
    edited June 2021
    Same here. I want also a manual download for the product, because I don't want to use DAZ Central.
    Post edited by RCTSpanky on
    Daz Central is not an option - if you see a product that lists only Daz central as an available emthod then it doesn't have any downloads.
    The lack of downloads is being investigated, I'm sorry it hasn't been fixed yet.
    edited June 2021
    Go to https://www.filterforge.com/download/ and download program here. Instal it and  open, ad your Serial Number when you registered it,  first DAZ-customer-xxxx and then "FF100W-VQT3......... You find them both in My Serial Numbers
    Thank you.
    barbult said:
    Thank you.
    I am glad to help you. Good if you understand my explanation in english, which is a foreign language to me
    MaARiTti said:
    barbult said:
    Thank you.
    Yes, I understood. yes Daz has still not addressed the missing download problem, so your advice was very useful, and it worked.
    barbult said:
    MaARiTti said:
    barbult said:
    Thank you.
    The downloads issue is being looked at, but I think it's waiting on someone who may not have checked their emails yet this weekend.
  • RAMWolffRAMWolff Posts: 10,359
    Thank you.  So the serial number finally appeared in my account.  I'll use the provided link to get my product.  Seems odd that DAZ isn't allowing us to download directly from their servers!
    indecision
    OK, I'm going to spit fire here.  Why does DAZ format the serials so badly?  I had to get out my older serial to know if I was doing it right but it seems that the Customer Name, no matter what I try, is wrong!  FFS!  angry
    Got it figured out but man what a PITA!
    And where is all this hidden:
    • NEW! Albedo, Height, Normal, Roughness, Metallic, Emission, and Occlusion channels
    Normal is the only one I can find.  Seems there is some information that't not being explained like if these are areas of the filters that are now supporting these maps or if this program now generates these sorts of maps for doing texture work.  One of the main reasons I upgraded.  So this is disapointing!
  • kyoto kidkyoto kid Posts: 41,984
    ...had the manual download option for ver 9.0 Pro.
    Have you set the Filter Type to PBR in the Result Conponent's settings?
    edited June 2021
    Hi Richard
    are you referring to the little area that's at the bottom of the UI: Draft, Final, Diffuse ........ ??
    Post edited by RAMWolff on
    edited June 2021
    Select the result brick and you should be able to change the Filter type in the panel at lower-left
    1053 x 766 - 342K
    Thank you so much Richard.  That's very very helpful for me!  laugh
    edited June 2021
    The render map options only appear if a particular filter employs those channels/options... otherwise you only see "Final" or "Normal" or whatever as the options.
    Previously it was a list with all the options and whatever wasn't available was grayed-out.
    With pre-made/existing/other people's filters you can access these maps options at the bottom of the screen... but once again, that depends on whether the filters have those maps... I have no idea why they moved it to the bottom (in 10) as it used to work fine located at the top, where it's been for years.
    It confused the hell out of me at first because the filters I was using the first time I used 10, only had "final" but then I noticed a newer filter had the other map options.
  • SapphireBlueSapphireBlue Posts: 1,373
    edited July 2021
    I bought Filter Forge 10 Pro (WIN) around the 15th, but still have not been able to register it. (The serial number in my account throws out an error.) Support staff told me it was a known issue that they are working on and that it's Windows users that have this problem.
    Does anyone else here also have this issue? I'm still just using the free trial version while I wait for it to get sorted, but it's taking rather long.
    Post edited by SapphireBlue on
