New install on new PC
Installed DAZ Studio to new computer.  Now Face Transfer is saying only have 3 saves remaining.  Can't seem to locate where I put the key for FT.
Also, install manager doesn't want to work anymore.  Enter username and pw and then it just quits.
  • KensaiKensai Posts: 32
    Hi sberlins, regarding your DIM issues, where it just quits after you login, sounds like you are having the same issue as I had. Are you using the latest version of Windows 21H1? Also are you using the 64bit of DIM? If so, your issue is most likely with a recent Windows update that is blocking some files Daz needs to run.
    Raise a ticket with support and they should be able to send you a fix to the login issue.
    edited June 2021
    The Key for Face Transfer would be in your Account on the page for serial numbers.
    Post edited by Catherine3678ab on
  • sberlinssberlins Posts: 128
    Raise a ticket with suTpport and they should be able to send you a fix to the login issue.
    Thanks will do!
    I know where to find the license key, the problem is where do you enter it?
  • TheKDTheKD Posts: 2,711
    Help menu > about installed plugins
    So that's where it was hiding!  Thanks.  That worked.
    All resolved.  Daz tech support sent some files to replace .dll's and works just fine.
