Where is Genesis 8.1? SOLVED
Fae3D
Ok, so I finally took the plunge and updated my Daz Studio to the latest upgrade (4.15, I think?). DForce seems to work, renders seem fine, it looks like things might be ok. But here's my question - where are Genesis 8.1 Male and Female? I installed the Genesis 8.1 Essentials and updated everything that wanted to be updated, but I don't have Genesis 8.1 in my Content Library or in my Smart Content. Am I mixed up, and Genesis 8.1 overwrote Genesis 8 with no name change or something? I thought we were supposed to be able to use both?
Also, I am not the best with computers. So I didn't do anything special, I just used DIM to update (I don't use Connect at all).
Edited to Update:
Uninstalling and then reinstalling the two Genesis 8 Starters Essentials fixed it. Odd, but ok!
Did you reinstall the starter essentials for G8? That's a good place to start. Then look in your figures area in smart content. In the content library, G8.1is in the same place as G8
Download Genesis 8 Starter Essentials Female & Male: the 8.1 ones are there.
I also kind of took the plunge but retained 4.12 because transp maps won't work in volumetrics for 4.15 and some key plug ins that I rely on a lot: Measure Metrics and ManFriday's dForce don't appear in D|S 4.15; I have to re-dock them in 4.12 whenever I open 4.15.
Hth!
Edit: too late
I only download manually, fwiw
I had to uninstall and reinstall the Genesis 8 Starter Essentials before I actually saw the base Genesis 8.1 figures in my Smart Content pane.
(It's kind of inconsistent that way.)
Perfect, uninstalling and reinstalling the Genesis 8 Starter Essentials did the trick. Very weird that that was neccessary, but hey, if it works it works.
Thank you very much, everyone!
