Free Carrara Items related to Carrara Challenge #58 - It's a Kind of Magic -
Headwax
Feel free to share any files or lighting setups or links with other members of the Carrara community here.
Here's a few magical symbols made with Philmeno's excellent cutout plugin . - Carrara Time Savers - Browse Files at SourceForge.net
The triquetre as clumsily modelled in the model room. The triple spiral you can take into the model room, select all and then Model>add thickness
I’m not sure how to upload a car file to sharecg – so hints on that would be handy.
These are just a couple of magical symbols. The txt suffix needs to be changed to car.
Post edited by Headwax on
to upload to ShareCG what I do is zip up the items and name the zip file accordingly for I.D. with no spaces and then just upload to my account at ShareCG and select the options for Carrara.. I use 7-zip to zip everything up.
same for the forum here...
just attach the zip file to your post like you would an image.
if this helps anyone .. I just knocked up a hat and wand ( modelled )
and I've added my bunny with a carrot as well.. it's all in the zip file
plus he will be handy for Easter - thanks Stezza :) thanks for the zip heads up too
Thank you, Headwax
Thank you, Stezza
Much appreciated
Here is a free version of my Crystal Ball WIP.
The crystal ball is a sphere made of 3 layers. The idea is to have the outermost sphere have a glass shader. The middle layer can have a cloudy shader. The innermost layer is designed to have a spherical render applied. In the zip, I have included a template for the uvmap and an example with a spherical render from a Howie Farks scene for the innermost layer along with the CAR file.
See attached zip.
yay, that's a beauty - I made one yeserday but I like yours better !! thanks
Some Magic Sparklies
Zip files
Butterfly. I did not include the texture because it would not upload, probably there is a size limit. The UVs are set up and ready to go to add your own wing texture, or just make them procedural...
thanks Bunyip02 et Mschack - looking forward to having a play with them!!
+1
Here is a freebie vintage barrel. I might use it in another idea I have. See attached zip file.
I've also included the texture map that I used as an attachment to this post if you get a load error.
presets between pc and mac
i'm on a win10pc, carrara set to feet.
what happens if the preset is opened on a mac set to cm ? it's going to work okay?
if i use a pbr shader and the machine it goes to doesn't have the pbr plugin,whats going to happen?
thank you Diomede :) that willc ome in handy!
sorry Mysty don't know the answer to that one
A - Carrara will automatically convert to the proper size - either making the file in the Mac use 'feet' or giving it the proper dimensions using the metric system.
B - An Error Has Occurred, as the plugin is required to utilize the shader contents
flutterbys
thanks
its like Merlin's circle stuff
think there a way to turn that into a container for the volumetric fire primitive?
it has cube and cylinder, but what about cusom shape, like a sphere or a taurus. a ring of fire!
found a couple things in store to help with an I Am Dragon
https://www.daz3d.com/sy-fire-within-genesis-8-and-81
https://www.daz3d.com/lightning-cosmetics-for-genesis-8.1-males-and-females
looks good Mysty - yes that three spiral thingy is a trispiral thingy :)
Here is a free 3 light setup of 3 models of spotlights. see attached zip.
And here is an object to look like a Carrara camera canonical See attached zip.
Thanks Ted. That will come in handy for making tutorials!
tutorials were approved.
Carrara, Layered Makeup tutorial using Rynne 8
Carrara - Make a quidk geoshell of G8F's face
