share UV set
AbnerKAbnerK Posts: 718
Hi, obvious out of the way first, I know I can't share a G8M mesh etc, however I know of people that have shared UV settings for G8M. So, how can I share the UV set I've made with a friend without giving them the mesh and having to explain to them how to import it and save that out so it's availabe next time?
thanks
Post edited by AbnerK on
  • FSMCDesignsFSMCDesigns Posts: 12,846
    I'd be interested in hearing an answer on this as well since the only way i know is to share the mesh with the new UVmap
  • Richard HaseltineRichard Haseltine Posts: 108,591
    Assuming the UVs are all your own work, File>Save As>Support Assets>UV Asset, then you save the relevant files in the same way as morphs etc.
  • AbnerKAbnerK Posts: 718
    Thanks, I'll try it. :)
