Free Carrara Items related to Carrara Challenge #58 - It's a Kind of Magic -
HeadwaxHeadwax Posts: 10,458
edited May 2021 in Carrara Discussion
Feel free to share any files or lighting setups or links with other members of the Carrara community here.
Here's a few magical symbols made with Philmeno's excellent cutout plugin . - Carrara Time Savers - Browse Files at SourceForge.net
The triquetre as clumsily modelled in the model room. The triple spiral you can take into the model room, select all and then Model>add thickness
I’m not sure how to upload a car file to sharecg – so hints on that would be handy.
These are just a couple of magical symbols. The txt suffix needs to be changed to car.
Post edited by Headwax on
  • StezzaStezza Posts: 8,881
    to upload to ShareCG what I do is zip up the items and name the zip file accordingly for I.D. with no spaces and then just upload to my account at ShareCG and select the options for Carrara.. I use 7-zip to zip everything up.
    same for the forum here... wink
    just attach the zip file to your post like you would an image.
    edited May 2021
    if this helps anyone .. I just knocked up a hat and wand ( modelled )
    and I've added my bunny with a carrot as well.. it's all in the zip file wink
    640 x 480 - 91K
    zip
    zip
    MagicianBundle.zip
    665K
    Post edited by Stezza on
  • HeadwaxHeadwax Posts: 10,458
    plus he will be handy for Easter - thanks Stezza :) thanks for the zip heads up too
  • DiomedeDiomede Posts: 15,401
    Thank you, Headwax
    Thank you, Stezza
    Much appreciated
    edited May 2021
    Here is a free version of my Crystal Ball WIP.
    The crystal ball is a sphere made of 3 layers.  The idea is to have the outermost sphere have a glass shader.  The middle layer can have a cloudy shader.  The innermost layer is designed to have a spherical render applied.  In the zip, I have included a template for the uvmap and an example with a spherical render from a Howie Farks scene for the innermost layer along with the CAR file.
    See attached zip.
    zip
    zip
    Crystal Ball ZIP.zip
    1M
    800 x 600 - 38K
    993 x 897 - 130K
    Post edited by Diomede on
    See attached zip.
    yay, that's a beauty - I made one yeserday but I like yours better !! thanks
  • Bunyip02Bunyip02 Posts: 9,290
    edited May 2021
    Some Magic Sparklies
    1000 x 1000 - 1M
    1000 x 1000 - 1M
    1000 x 1000 - 1M
    1000 x 1000 - 1M
    1000 x 1000 - 1M
    Post edited by Bunyip02 on
    Zip files
    zip
    zip
    Magic Sparkly 1.zip
    1M
    zip
    zip
    Magic Sparkly 2.zip
    1M
    zip
    zip
    Magic Sparkly 3.zip
    1M
    zip
    zip
    Magic Sparkly 4.zip
    1M
    zip
    zip
    Magic Sparkly 5.zip
    1M
  • mschackmschack Posts: 337
    edited May 2021
    Butterfly.  I did not include the texture because it would not upload, probably there is a size limit.  The UVs are set up and ready to go to add your own wing texture, or just make them procedural...
    zip
    zip
    butterfly1.zip
    11K
    1858 x 1080 - 196K
    Post edited by mschack on
    thanks Bunyip02 et Mschack - looking forward to having a play with them!!
    +1
    edited June 2021
    Here is a freebie vintage barrel.  I might use it in another idea I have.  See attached zip file.
    I've also included the texture map that I used as an attachment to this post if you get a load error.
    zip
    zip
    Barrel for Magic Dio Zip.zip
    306K
    800 x 600 - 30K
    1600 x 1600 - 285K
    presets between pc and mac
    i'm on a win10pc, carrara set to feet.
    what happens if the preset is opened on a mac set to cm ?  it's going to work okay?
    if i use a pbr shader and the machine it goes to doesn't have the pbr plugin,whats going to happen?
    thank  you Diomede :) that willc ome in handy!
    sorry Mysty don't know the answer to that one
  • DartanbeckDartanbeck Posts: 21,988
    A - what happens if the preset is opened on a mac set to cm ?  it's going to work okay?
    B - if i use a pbr shader and the machine it goes to doesn't have the pbr plugin,whats going to happen?
    A - Carrara will automatically convert to the proper size - either making the file in the Mac use 'feet' or giving it the proper dimensions using the metric system.
    B - An Error Has Occurred, as the plugin is required to utilize the shader contents
    flutterbysheart thanks
    its like Merlin's circle stuff
    See attached zip.
    think there a way to turn that into a container for the volumetric fire primitive?
    it has cube and cylinder, but what about cusom shape, like a sphere or a taurus.  a ring of fire!
    Mystiara said:
    found a couple things in store to help with an I Am Dragon
    https://www.daz3d.com/sy-fire-within-genesis-8-and-81
    https://www.daz3d.com/lightning-cosmetics-for-genesis-8.1-males-and-females
    looks good Mysty - yes that three spiral thingy is a trispiral thingy :)
    edited June 2021
    Here is a free 3 light setup of 3 models of spotlights.  see attached zip.
    zip
    zip
    Zip 3 Spot OBJ.zip
    4K
    1881 x 965 - 222K
    And here is an object to look like a Carrara camera canonical   See attached zip.
    zip
    zip
    Zip OBJ Camera Carrara.zip
    26K
    1252 x 617 - 107K
    Thanks Ted. That will come in handy for making tutorials!
