Problem with deformed fingernails - SOLVED
HoMartHoMart Posts: 488
edited May 2021 in The Commons
Hi
I need some help, clues, point at ... to get rid of the deformed fingernails as shown in the image.
shown in the image is Genesis 8 Basic Female without any other morphs.
In the image you see HighResolution and SubDivision Level 1
also the knuckles look strange.
It´s solved
It was releated to some X-Transfer stuff/morphs - deleting them solved the problem
Post edited by HoMart on
  • run4realrun4real Posts: 94
    Set Resolution Level from Base to HighResolution and SubDivision Level to 1 should solve this.
  • HoMartHoMart Posts: 488
    Thank you for the answer but the Genesis 8 Basic Female is loading at HighResolution and SubDivision Level 1.
  • felisfelis Posts: 5,999
    And when you say without morphs, have you then looked in Parameters > Currently used, with Show Hidden enabled?
  • SeraSera Posts: 1,675
    Right click on the parameters tab and select show hidden properties. Then check currently used for anything that might be dialed in that shouldn't be.
    yes, all hidden and unhidden are set to Zero.
     Thanks. Yes I checked for hidden properties - is all set to zero in the screenshot
    and SubDivisionAlgorithm to Catmark?
    Yes,
    Its Genesis 8 Basic Female "out of the box" - just fresh loaded to the scene - all currently used (like Eyelashes etc) hidden and unhidden set to zero
    and is still looking like that, I don´t know where to look else.
    If you load the base character yo an empty scene, could you then paste the load section from the log file?
     2021-05-29 11:18:53.527 Begin Loading Character Addons...
    2021-05-29 11:18:54.594 File loaded in 0 min 1.0 sec.
    2021-05-29 11:18:54.595 Loaded file: Genesis 8 Female Eyelashes.duf
    2021-05-29 11:18:54.609 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.611 Loaded file: Vagina_UltraPenet-Tight_key.dsf
    2021-05-29 11:18:54.612 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.614 Loaded file: Vagina_SupPenet-Tight_key.dsf
    2021-05-29 11:18:54.615 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.617 Loaded file: Vagina_Penet-Tight_key.dsf
    2021-05-29 11:18:54.618 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.619 Loaded file: default-shape.dsf
    2021-05-29 11:18:54.620 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.622 Loaded file: !Tight Vagina.dsf
    2021-05-29 11:18:54.628 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.629 Loaded file: XT_PHMMouthRealismHD.dsf
    2021-05-29 11:18:54.631 WARNING: QFSFileEngine::open: No file name specified
    2021-05-29 11:18:54.631 WARNING: ..\..\..\..\..\src\sdksource\general\dzmorphdeltas.cpp(784): Could not open HD file:
    2021-05-29 11:18:54.633 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.634 Loaded file: PHMEyelashesLengthUpper.dsf
    2021-05-29 11:18:54.635 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.636 Loaded file: PHMEyelashesLengthLower.dsf
    2021-05-29 11:18:54.638 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.639 Loaded file: PHMEyelashesCurl.dsf
    2021-05-29 11:18:54.776 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.777 Loaded file: PHMEyelashesLengthUpper.dsf
    2021-05-29 11:18:54.778 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.779 Loaded file: PHMEyelashesLengthLower.dsf
    2021-05-29 11:18:54.780 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.781 Loaded file: PHMEyelashesCurl.dsf
    2021-05-29 11:18:54.783 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:18:54.784 Loaded file: PHMEyelashesExpand.dsf
    2021-05-29 11:18:55.333 File loaded in 0 min 0.0 sec.
    2021-05-29 11:18:55.333 Loaded file: Base MAT Eyelashes.duf
    2021-05-29 11:18:55.335 Finished Loading Character Addons
    2021-05-29 11:18:55.669 File loaded in 4 min 34.9 sec.
    2021-05-29 11:18:55.673 Loaded file: Genesis 8 Basic Female.duf
    2021-05-29 11:19:11.508 Loaded image G8FBaseLegsMapD_1003.jpg
    2021-05-29 11:19:11.655 Loaded image G8FBaseEyes01_1007.jpg
    2021-05-29 11:19:11.841 Loaded image G8FBaseArmsMapD_1004.jpg
    2021-05-29 11:19:11.900 Loaded image G8FBaseMouthMapD_1005.jpg
    2021-05-29 11:19:12.089 Loaded image G8FBaseFaceMapD_1001.jpg
    2021-05-29 11:19:12.261 Loaded image G8FBaseTorsoMapD_1002.jpg
    2021-05-29 11:19:12.321 Loaded image G8FBaseEyelashes_1006.jpg
    You have some additional morphs in there - only the eyelashes should be there.
    Why they don't show up in the parameters tab, I don't know.
    It doesn't look like, based on their names, that they should affect your hands, but no way to know for sure.
    Is this problem one you have discovered by random, ie can have been there for a long time, or do you know if it is one that have happened recently?
     THANK YOU for pointing me to the logfile and take a closer look there.
    It was releated to some X-Transfer stuff - revoving the "XT_PHMMouthRealismHD.dsf" and some other XT_ morphs I do not use solved the problem.
    Genesis 8 Base Female loading with normal nails again.
    I think felis thoughts show in the right direction e.g. my log looks very different after loading the base character:
    2021-05-29 11:37:14.559 Begin Loading Character Addons...
    2021-05-29 11:37:14.655 File loaded in 0 min 0.0 sec.
    2021-05-29 11:37:14.656 Loaded file: Genesis 8 Female Eyelashes.duf
    2021-05-29 11:37:14.658 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:37:14.659 Loaded file: PHMEyelashesLengthUpper.dsf
    2021-05-29 11:37:14.660 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:37:14.660 Loaded file: PHMEyelashesLengthLower.dsf
    2021-05-29 11:37:14.660 Loaded file: PHMEyelashesCurl.dsf
    2021-05-29 11:37:14.679 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:37:14.679 Loaded file: PHMEyelashesLengthUpper.dsf
    2021-05-29 11:37:14.680 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:37:14.681 Loaded file: PHMEyelashesLengthLower.dsf
    2021-05-29 11:37:14.682 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:37:14.682 Loaded file: PHMEyelashesCurl.dsf
    2021-05-29 11:37:14.683 Loaded Morph Deltas in 0 min 0.0 sec.
    2021-05-29 11:37:14.684 Loaded file: PHMEyelashesExpand.dsf
    2021-05-29 11:37:14.778 File loaded in 0 min 0.0 sec.
    2021-05-29 11:37:14.779 Loaded file: Base MAT Eyelashes.duf
    2021-05-29 11:37:14.781 Finished Loading Character Addons
    2021-05-29 11:37:14.823 File loaded in 0 min 12.7 sec.
    2021-05-29 11:37:14.825 Loaded file: Genesis 8 Basic Female.duf
    2021-05-29 11:37:15.833 Loaded image G8FBaseLegsMapD_1003.jpg
    2021-05-29 11:37:15.868 Loaded image G8FBaseEyes01_1007.jpg
    2021-05-29 11:37:15.993 Loaded image G8FBaseArmsMapD_1004.jpg
    2021-05-29 11:37:16.028 Loaded image G8FBaseMouthMapD_1005.jpg
    2021-05-29 11:37:16.157 Loaded image G8FBaseFaceMapD_1001.jpg
    2021-05-29 11:37:16.272 Loaded image G8FBaseTorsoMapD_1002.jpg
    2021-05-29 11:37:16.309 Loaded image G8FBaseEyelashes_1006.jpg
    2021-05-29 11:37:16.521 Loaded image G8FBaseTorsoMapB_1002.jpg
    2021-05-29 11:37:16.672 Loaded image G8FBaseTorsoMapS_1002.jpg
    2021-05-29 11:37:16.781 Loaded image G8FBaseTorsoMapSSS_1002.jpg
    2021-05-29 11:37:16.949 Loaded image G8FBaseFaceMapS_1001.jpg
    2021-05-29 11:37:17.078 Loaded image G8FBaseFaceMapB_1001.jpg
    2021-05-29 11:37:17.205 Loaded image G8FBaseFaceMapSSS_1001.jpg
    2021-05-29 11:37:17.241 Loaded image G8FBaseMouthMapB_1005.jpg
    2021-05-29 11:37:17.365 Loaded image G8FBaseLegsMapSSS_1003.jpg
    2021-05-29 11:37:17.521 Loaded image G8FBaseLegsMapS_1003.jpg
    2021-05-29 11:37:17.654 Loaded image G8FBaseLegsMapB_1003.jpg
    2021-05-29 11:37:17.779 Loaded image G8FBaseArmsMapSSS_1004.jpg
    2021-05-29 11:37:17.907 Loaded image G8FBaseArmsMapB_1004.jpg
    2021-05-29 11:37:18.073 Loaded image G8FBaseArmsMapS_1004.jpg
    2021-05-29 11:37:18.107 Loaded image G8FBaseEyesB_1007.jpg
    2021-05-29 11:37:18.575 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseTorsoMapD_1002.jpg
    2021-05-29 11:37:20.712 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseTorsoMapS_1002.jpg
    2021-05-29 11:37:20.993 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseTorsoMapSSS_1002.jpg
    2021-05-29 11:37:21.068 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseTorsoMapB_1002.jpg
    2021-05-29 11:37:22.008 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseFaceMapD_1001.jpg
    2021-05-29 11:37:22.815 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseMouthMapD_1005.jpg
    2021-05-29 11:37:23.678 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseMouthMapB_1005.jpg
    2021-05-29 11:37:23.857 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseFaceMapS_1001.jpg
    2021-05-29 11:37:24.067 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseFaceMapSSS_1001.jpg
    2021-05-29 11:37:24.381 Ran tdlmake on image F:/!CONTENT/Studio4/Runtime/Textures/DAZ/Characters/Genesis8/FemaleBase/G8FBaseFaceMapB_1001.jpg
