should I allow this?
iIsabeauiIsabeau Posts: 0
Hello,
After updating Daz Studio, and downloading/ installing many new items, I suddenly received a box that says to either allow or deny 'Postgres" to accept incoming network connections.
It is actually a message from my mac system.
And this message can not be closed without answering it's question.
I assume this is for downloading and installing items.
Am I 'safe' to allow this connection?
Is this a two way path for information?
I am on a Mac using the latest update of Lion.
Thanks!
  • fixmypcmikefixmypcmike Posts: 19,710
    It's the replacement database for CMS, it doesn't actually accept or receive information outsider of your computer, it only communicates with DAZ Studio over a port that's local to your computer.
  • iIsabeauiIsabeau Posts: 0
    "Thanks Fixmypcmike!"
    I am new to this added program and wanted to be sure.
  • FishtalesFishtales Posts: 6,224
    It is the firewall refusing access to the port DAZ uses to communicate with the CMS database. I had that trouble with COMODO on windows and couldn't see the Smart Content. Once I allowed access to the port everything worked fine. I now have COMODO set to inform me of any blocked content, called learning mode, so that I can allow or refuse access as required. I also check COMODO now and again to check what it is refusing access to just in case it is refusing access to something I need :-)
