Bryce Pro 7.0 Pro Content install error
I downloaded DAZ 3D and also Bryce 7.0 Pro Content.
Does anyone have a fix for this: "Bryce was not found in the chosen location, which may cause the content to not function properly."
Install Bryce 7 pro. The content needs the program before it will work. Bryce 7.1.0.109.
Thank you. Thought I had done that already.
Are you using DIM to download and install?
If so you need to make sure that you have directed the content to the exact path where you have Bryce 7 Pro installed.
