Smay's Super Hero effects problem
https://www.daz3d.com/superhero-body-fx-for-genesis-8-females
Applying these effects and I get weird results. Shows up in iRay, looks fine in texture shaded mode. Also happens on the arms.
Someone said it's the geoshell and I need to "increase the offset". Afraid I'm not sure what they mean by that.
There doesn't appear to be a geoshell to select. If I choose "Face FX 01" there is no setting for "Geoshell Offset" (or anything similar)
Thank you! Adding the push modifier helped. It cleared it up on the arms pefrectly, the face it left a bit (pictured) that I can maybe fix in post.
