Fitting Genesis2 Prop to Genesis ?
It looks like Genesis accessories can be auto-fitted to Gen2 figures. What about the other direction?
Is there a built-in (or free) way to get Gen2 wardrobe onto Gen1 figures ?
You can try to load it, if the box pops up asking which figure it's made for choose unsupported and see how bad it gets mangled. If it's an unusable mess then go to parameters and change fit-to to none. Drag the item over the body part you want it stuck to in the scene tab (neck for a necklace, head for earrings, this is called parenting.) Adjust the translation and scale dials in parameters until it looks okay. you might have to do some more fine tuning after posing the figure but you can get most things to fit pretty well with that method.
Edit- for clothes it's harder.. you have to leave them fit-to, but you can crank up the smoothing iterations and that usually helps.
Worked like a charm. Thank you very much !
