Alaena's Titanic freebie
sriesch
Does anybody know if it is possible to get Alaena's free Titanic model for Poser working in DAZ Studio? After mapping the content folder, DAZ Studio doesn't see any files when I scan for them. I'm wondering if it's a Poser-only thing somehow, or if I have to manually move files around, or something else.
http://www.sharecg.com/v/39256/browse/5/3D-Model/Titanic-Poser-6-version
I've sen obj files with nothing there, requires a import, then save as duf (scene subset, material preset, whatever it is.). Also Daz Studio will only show Poser files in the "content library", IF there in the "Poser Formats" path.
beyond that, I am not that savvy with the Content library.
(EDIT)
look at my cover gallery link below. The skirt I could not make work, the hair Did in the end. They were Poser only things from sharcg.
You need to add a "Libraries" folder in the "Runtime" folder then a "Props" folder in the "Libraries" folder. Drag and drop the "Titanic" folder in to the "Props" folder.
This particular item is a Poser pz3 scene file. It should load up in Daz Studio. Placing the pz3 file anywhere under Runtime/Libraries/Props will allow Studio to recognize it. The texture files need to go in Runtime/Textures. I will try it later. Some pz3 scene files load OK in DS, some do not.
@jestmart, thanks, that did the trick!
