Solving Problems BVH-Import
I was not able to find a solution for my problem in the forum.
I have a complex movement that I want to animate. For this I import a bvh file.
The movement is actually well presented, only in detail there are clear differences to the original movement.  For example, the arms are not bent correctly.
The hierarchy is correct and the assignment of the joints are also correct.
What causes the differences and how can I correct them?
Thanks for any ideas
Kind regards
Nik
  • wolf359wolf359 Posts: 3,936
    Use the graph editor.
  • niklasnothniklasnoth Posts: 0
    Thanks for the tip. I have also considered to use the graph editor.
    Since it is a complex movement with 240 frames, a manual adjustment is not really an option.
    Is it normal, the there is difference to the original movement?
    Any other ideas?
    Kind regards
    Nik
