Lipsync - analyze crashes!
ancichancich Posts: 26
I have been playing around with Lipsync in the 32 bit version of DazStudio v 4.6 and had no problems until today. I loaded a 10 minute long wav file and after I press the analyze button, I get an error about 2 seconds later. The log file of the error is shown below, but doesn't tell me anything. Is there some limitation on the length of the wave file? The wav file plays fine in windows media player and other players, so I very much doubt it is the wav file itself
ERROR LOG:
Mimic TalkBack analysis error: TALKBACK_ANALYSIS_FAILED_ERR: analysis failed [the sound file cannot be analyzed or an internal error occurred]
    I doubt if Lipsinc was ever designed for ten minute audio files, that seems very long indeed to me.
    Do you have any other files that you could try of a similar length to see if they work/ There may be a problem with the audio file that doesn't show up when played in a media player, but may cause Lipsync to have problems.
    You could try splitting the audio into shorter chunks?
