How Exactly DO you Use GenX2 it says Morphs should be in the morphs folder for the according figure
What to do? I'm trying to convert a michael 4 figure to genesis 2. I first shaped it with Body morphs and head morphs, then I saved to the libraries as a .CR2 file cause that's the only way i can drag it to the GenX2 window, then in the window, it has al my Body morphs and head morpsh etc, i push the select button and choose "Transfer ON for all Non Zero values" . Then finally i get this message
Post edited by nokoteb99 on
This is the error
To see larger print, hold down the Ctrl key and scroll the webpage larger or smaller. Shouting at the crowd is not required ;-)
AFAIK 2 products are required to do what you want:
https://www.daz3d.com/genesis-generation-x2
https://www.daz3d.com/genx2-addon-for-genesis-2
Then to polish off the look so that Genesis/Genesis 2 can look like the legacy figures, one or more of these products are required:
https://www.daz3d.com/v4-and-m4-shapes-for-genesis
https://www.daz3d.com/generation-4-legacy-shapes-for-genesis-2-female
https://www.daz3d.com/generation-4-legacy-shapes-for-genesis-2-male
https://www.daz3d.com/michael-4-for-genesis-2-male
And here are a couple of "how-to" videos:
