ISO a Sinkhole or broken earth product
Geminii23
in The Commons
I'm trying to create an image of a sinkhole opening up in the ground. I would prefer to do this all in DS instead of diving into Photoshop for postwork to achieve. Does anyone know if there is some kind of environment options like a cave opening? Crumlbed ground? Earthquake perhaps?
Cheers!
Maybe this:
https://www.daz3d.com/tropical-cave
These may work for some angles or be used for kitbashing:
https://www.daz3d.com/the-watering-hole
https://www.daz3d.com/1stb-brookside-path
https://www.daz3d.com/modular-cove-landscape-creator
This island seems to have something akin to a sinkhole:
https://www.daz3d.com/pw-reef-island
It all depends on what type of sinkhole exactly are you looking for.
These may also help you:
https://www.daz3d.com/catalogsearch/result/?q=meshgrabber
I was reading about this product the other day... https://www.daz3d.com/gescon-constructive-solid-geometry-for-daz-studio
If you can't eventually find something that fills your need and you don't really do modeling, you could use the tools in the above plugin to cut a hole in a large thin cube... the mesh has to be closed for the plugin to work, so that's why it can't be a plane, so you need to size/flatten an appropriately sized cube to the dimensions that works best, before you cut a hole through it using the plugin.
Please note: I don't own the product, but it sounds like it would work.
Here is a thread about the product... https://www.daz3d.com/forums/discussion/492561/released-gescon-csg-plugin-for-daz-studio-commercial/p1
Thank you all for the great suggestions. I think some of these just might work. Cheers!
Might be useful. Obviously not everybody has or is comfortable using C4D, but I imagine a lot of the methods carry over to Blender et al.
This one's on Share CG and is free.
..Joe
https://www.sharecg.com/images/medium/175736.jpg
http://sharecg.com/v/96478/related/21/DAZ-Studio/The-Pit-For-Halloween
