Trouble Instaling TonnyCam Pro
Just like the title says I can not install TonnyCam Pro onto my computer properly. Im using Daz 4.12.1.118 (64-bit) and runing Windows 10.
The install says that it can not find Daz. (see atached file) When I try to run it, it says it can not find a file. (see other attached file)
I have had it installed before with earlier versions of Daz but I do not see why I am having this issue.
Thanks in advance for you help.
  • Richard HaseltineRichard Haseltine Posts: 109,062
    How did you install Daz Studio? Ideally you should use the same method for things that install like plug-ins (as I recall Toony Cam isn't a plug-in, but it does place some files it the application folder).
  • I intsalled Daz the same way I always have using the DIM. ToonyCam Pro is an .exe file. This is the same arangement as the last time I used it with an earlier Daz version. It sould work with Daz 4.x though.
    Try installing Toony Cam through Install Manager.
  • brucefoster369brucefoster369 Posts: 13
    edited May 2021
    I would. That would solve everything, however, it was only ever released as an .exe file and Daz no longer supports it.
    Post edited by brucefoster369 on
