Torment 8.1 Outfit?
simon_3872481simon_3872481 Posts: 20
edited May 2021 in Product Suggestions
Can anyone please advise what outfit Torment 8.1 is wearing in these promotion photos?
See here: https://www.daz3d.com/essential-poses-for-torment-8
Thanks
  • Richard HaseltineRichard Haseltine Posts: 109,054
    Moved to Product Suggestions as it is not a Daz Studio question.
  • QuixotryQuixotry Posts: 919
    Zombietaggerung is correct. I used the tunic from that set. If you want it to have that color as well, that green comes from a shader in this pack. Just a note, if you're using dForce with the tunic and tail, if you hide the topmost section of the tail (the part that touches the base of his spine) in the Scene tab, it can help prevent the tail clipping through the cloth and causing it to explode during the simulation. Hiding the entire tail is usually simplest, but if you expect a part of the tail to push the fabric around the legs, you can just hide those bits. I turned off the visibility of the first two sections, I think, just to be sure the base of the tail didn't interfere with the cloth during simulations.
