NEW 2021 Sales thread: Report Issues Here "There's Always Another Sale™"
15960626465100
    Seems contrary to the "*Coupon valid twice per customer. Excludes Gift Cards, Subscriptions, and Memberships. Expires 05/19/21 12AM MDT UTC -6" coming with the TIME2SHOP coupon it only seems to work once?!?
    Or is there now more wisdom about which DOs it's (still) to work, as it seemed to work on ALL DOs - including new PC+ items for example - yesterday?!?
  • N-RArtsN-RArts Posts: 1,606
    edited May 2021
    L4N4 is only has Daz Connect as an install type:
    https://www.daz3d.com/l4n4-hd-morph-for-genesis-8-females
    I originally posted about it in a seperate thread: https://www.daz3d.com/forums/discussion/495076/l4n4-daz-connect-only#latest
    Late edit: I meant Daz Central ^^'
    Post edited by N-RArts on
  • Cris PalominoCris Palomino Posts: 12,554
    Will report.
  • doubledeviantdoubledeviant Posts: 1,345
    I was able to successfully use it yesterday, but contrary to the description, it doesn't seem to work a second time.
    edited May 2021
    Sending inquiry
    Edit: the TIME2SHOP coupon I see does not mention it being usable more than once. It was a different onsite coupon, BUNDLELOVE, which could be used twice.
    Post edited by Cris Palomino on
  • watchdog79watchdog79 Posts: 1,026
    Cris Palomino said:
    Sending inquiry
    From my e-mail - see the word "twice" below the red arrow I added:
    982 x 554 - 91K
  • BlueFingersBlueFingers Posts: 904
    Cris Palomino said:
    Sending inquiry
    It does say it can be used twice in the email, see this link: http://email.daz3d.com/public/viewmessage/html/23560/cj87crsgie72lzk7xo14ojwc0vqmn/0bc403eb000000000000000000000014bf60
    No mention of a BUNDLELOVE coupon, so it must apply to the TIME2SHOP coupon right? It would make sense as it's valid for a few days.
    1920 x 1080 - 211K
    watchdog79 said:
    Cris Palomino said:
    Sending inquiry
    Thanks, I will pass this on to Daz.
  • bishboschbishbosch Posts: 53
    Yeah, TIME2SHOP isn't working for me a second time either. Also I'd like to know what the Select Daz Originals are as that Shop Now link just brings up the regular main storefront page.
    It should now be usable twice and it's all daz originals except giftcards and pc+ membership.
    Thank you.yes
  • mdl062168mdl062168 Posts: 84
    edited May 2021
    I can't get it to apply even once for any Dazz Original that is new, even though the email link takes me to a page with all Dazz Originals listed, new and old.  I can only get the coupon to "apply" if I have non "new" Dazz Originals in my cart, otherwise it errors out that the "Coupon is not valid."
    1867 x 585 - 87K
    1893 x 513 - 78K
    Post edited by mdl062168 on
  • Joe2018Joe2018 Posts: 290
    I think from the first screenshot: these are all not "DAZ Originals".
    The link in the Mail takes you to the normal store page. You must select "DAZ Originals" under Artists.
  • Cris Palomino said:
    Sending inquiry
    Is there a known expiry date for the  BUNDLELOVE coupon, i want to save it for when it really counts but don't want to waste it if it will expire soon (the email didn't state an expiry)?
  • LeanaLeana Posts: 12,806
    None of the items in your first screenshot are Daz Originals.
  • Charlie JudgeCharlie Judge Posts: 13,286
    Faster than a blink sale. The Weapons and Warfare Flash sale was only up for a couple of hourscrying I sure hope it comes back
  • Abstract SoulAbstract Soul Posts: 169
    There was a super blink and miss eastern sale right after the weapon and warfare sale. The items from the Eastern sale show a discount in the link, then show 0%off when in cart and the banner has been taken down. weird
    https://www.daz3d.com/save-on-select-eastern
  • XanathonXanathon Posts: 88
    L4N4: https://www.daz3d.com/l4n4-hd-morph-for-genesis-8-females
    Installed via DIM.
    Body materials cannot be applied. Error: "An error occured while reading the file, see the log for details."
    Log:
    2021-05-17 22:46:54.772 Error reading file, see log for more details.<br /> 2021-05-17 22:46:55.424 Iray [INFO] - IRAY:RENDER ::&nbsp; &nbsp;1.0&nbsp; &nbsp;IRAY&nbsp; &nbsp;rend progr: Received update to 01584 iterations after 14.825s.<br /> 2021-05-17 22:46:56.878 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json) failed: HTTP response code said error<br /> 2021-05-17 22:46:56.878 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (80611) failed, url: https://cdn.daz3d.com/file/dazcdn/p/11/80611/meta/80611_a1e45f_data.json<br /> 2021-05-17 22:46:56.878 Updated metadata for 4 of 5 items.<br /> 2021-05-17 22:46:56.915 Iray [INFO] - IRAY:RENDER ::&nbsp; &nbsp;1.0&nbsp; &nbsp;IRAY&nbsp; &nbsp;rend progr: Received update to 01798 iterations after 16.316s.<br /> 2021-05-17 22:46:57.277 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://cdn.daz3d.com/file/dazcdn/p/83/72283/meta/72283_d76c27_file.json) failed: HTTP response code said error<br /> 2021-05-17 22:46:57.277 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): TaskLoadProductDataWeb (72283) failed, url: https://cdn.daz3d.com/file/dazcdn/p/83/72283/meta/72283_d76c27_file.json<br /> 2021-05-17 22:46:57.277 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed with errors, 3 items succeeded, 2 items failed.<br /> 2021-05-17 22:46:57.277 Metadata update failed: 3 items succeeded, 2 items failed.
    Uninstalled and reinstalled. Download failed multiple times.
    After multiple installation trieds it installed. Still the same problems.
  • SevrinSevrin Posts: 6,313
    The flash sale for "interactive figures" is acutally for interactive poses
  • UthgardUthgard Posts: 878
    I've had to dump the cart twice already because the sale ended too quickly. It's uncanny how good Daz has become at helping me save money.
  • 31415926543141592654 Posts: 975
    I think I will give up also. The sales categories are interesting for myself ... but taking the time to make a cart and then have the discount disappear before I can check out is getting too frustrating. There is always another sale ... ... ...
  • tsroemitsroemi Posts: 3,507
    The flash sales worked for me twice today, which was cool, and failed me the third time because it ended too quickly. That was rather good though, too because I had gotten a bit lost in the heat of the moment and put just too many things in my cart which I don't really need atm. Still waiting whether there'll be another one though ... ;-)
  • HoMartHoMart Posts: 487
    Installed via DIM.
    Log:
    2021-05-17 22:46:55.424 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01584 iterations after 14.825s.
    2021-05-17 22:46:56.915 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01798 iterations after 16.316s.
    same here
    NONE of the H.Materials is working
    Installed via DIM.
    Log:
    Please submit a ticket.
    Flash sale: buy some items plus a new item ... 70% off of the Flash Sale items [not the new item]. Right. Except that wasn't working. Tried several combinations none of which worked.
    So no sale.
    What that 70% discount seems to be doing is to be calculated from the FULL price, not the price otherwise showing to us. AFAIK that's a first. Normally discounts are calculated in some weird fashion from the price shown.
    Well I was finally able to check out with a flash sale before prices changed but I purchased less than I would have if I knew when the sale would end. I was in a hurry to check out before prices might randomly change, so just quickly threw some things in that I had in my cart earlier but if I knew how much time I had, I would have purchased more. Daz really needs to put a timer with a countdown on it so we know exactly how much time we have. They are losing money and frustrating customers by doing it this way,,,
    So no sale.
    The discount is in place of the initial discount, not in addition to, if you read the text again. 50% becomes 60% with two items, 65% with 3, 70% with 4. This type of sale is certainly not new.
  • Hurdy3DHurdy3D Posts: 1,076
    You've added several of our 2021 Daz Original Bundles to your library! We're glad you're loving them, so enjoy an EXTRA 20% OFF the Drago Fire and Fury Bundle
    Discount valid for intended recipients only.
    Seems not to work for me. Get only 30% for a new realase and 30% for beeing a DAZ original.
  • Robert FreiseRobert Freise Posts: 4,607
    Not working for me either at this time
  • Lothar WeberLothar Weber Posts: 1,611
    Same here. Discount not working!
