Blured tattoo
I am coloring a tattoo, but when I render, it appears blurry, I don't know what I am doing wrong.
  • GordigGordig Posts: 10,624
    It looks like it's just enhancing the artifacting that's visible in the original image. What format are you saving the file in? You'll probably have better results saving in an uncompressed format with fairly high resolution.
  • charlescharles Posts: 866
    Like Gordig said, Render Settings, Advanced Tab, raise the medium and high thresholds.
  • TlameteotlTlameteotl Posts: 41
    The image resolution was 72 and I change it to 300 and work perfectly, thank you very much, now I hope the render time don't go to the clouds :D  I tryied changing the texture compression but it did´t change anything... Thanks for the help!
    Exactly why I never work with JPG, always use PNG myself, lossless compression.
