Finger clipping issue
I've been playing around with RawArt's She Orc figure and while it looks fantastic, I've noticed an issue with the fingers clipping through her nails. However, only the Iray material makes this happen and the 3Delight one works just fine. Is there any way one could fix this?
  • Richard HaseltineRichard Haseltine Posts: 108,149
    That looks like an issue with the displacement settings, is it a full render or a preview (as I recall displacement isn't on in Iray preview mode).
  • AdytumAdytum Posts: 0
    Dang, I knew I forgot to mention something! It is, indeed, a full render. Seems to only happen when rendering, too. I'm assuming these displacement settings are the culprit then? I'm unfamiliar with them.
    In the Surfaces pane's Editor tab, since there are no issues elsewhere I would assume it is the nail settings.
    I did some poking around/experimenting and while changing the displacement for the nails seemed to work somewhat, lowering the displacement on the skin is what ended up doing the trick. Thank you for the help!
