Shadow Catcher
Hi, Struggling to find any recent / relevant info on this topic but is it safe to assume that the shadow catcher brick is broken in 4.15?
    Hi! You mean for 3Delight? There are no 3DL updates since 2015 so I can't see why it should be broken. However I can't test it myself. still using DS 4.9. Here's a tutorial on how to set it up in shadermixer if that's of any help:
    Create a shadowcatcher in Shader Mixer
  • MattB123MattB123 Posts: 36
    I dunno. I've never really bothered experimenting with them but "Matte Material" doesn't seem to work in iray so trying to get something workable
    Ok, can't help you then, I don't use IRay. The shadowcatcher brick is RSL so it only works in 3DL.
    Yea I figured as much. I have a workaround but it's last resort. Just using the draw ground and moving the ground would do the trick but it feels like there should be a more elegant way of doing it
  • Richard HaseltineRichard Haseltine Posts: 108,524
    For 3Delight?
    Im actually looking to create a shadow catcher for iRay in 4.15 but the matte property doesn't seem to work. I'd prefer to avoid 3Delight but not sure what else my options are
    What happens with the Iray Matte? It worked for me just now, in a simple scene with a plane, a cylinder, and a spotlight, though it does catch reflected light as well as shadows which might not be what you want.
    1000 x 1000 - 668K
    Using a plan, I apply the matte and it just remains a white plane. I turn on and off iray mode, i change between photoreal and interractive, i hide and show the plane, still it remains a white plane.
    Its probably a simple error on my part but i can't seem to get it working
    So it turns out that having the plane inside an enclosed space is causing the matte material not to work.
    If there are any external lights (e.g. an HDR or Sun/Sky) then the whole of the enclosed plane will be shadowed.
    That makes sense. My expectations were a little too high.
