Getting the hair to fit under the mask
Okay, another tribute to my DC Comics heroes, this is my version of Tim Drake Robin and a cuter (IMO) version of Cassandra Cain Batgirl.  I'm 99%happy with it, but I'd prefer it if her hair fit completely under the mask, save for the nape of the neck, which is supposed to stick out.
Any suggestions?
  • y3kmany3kman Posts: 856
    You could hide parts of the hair geometry or use dformers to pull the hair inside the figure's head.
    There are some hair helper products being sold but I never found success in using them.
  • zombietaggerungzombietaggerung Posts: 3,886
    or do the main render with the hair showing, then hide it and do a spot render and blend them in post.
  • MisselthwaiteMisselthwaite Posts: 961
    I usually make a copy of the item (mask, in this case) and give the hair a smoothing modifier with the item as the collision.  Then I make the copy invisible, and make the original a little bit larger.  That usually takes care of most of my problems, but sometimes I use hair morphs to tweak if I have a big section sticking out, or use Mesh Grabber to nudge and tuck.
    This.  I was literally driving myself crazy for years trying to hide hair.  Simple compositing in post.
  • comixfanacomixfana Posts: 277
    Fixed it!  Turns out I had purchased SY Hat and Hair Helper a few years ago and forgot I had it...after a refresher, I redid Batgirl's hair and it now looks the way I intended it!
    824 x 665 - 1M
    824 x 665 - 1M
    824 x 665 - 1M
