Suggestion for a future DS update
Masterstroke
With all the huge amount of .../data/... files, it would be nice, to have the option to browse directly to the referring .../data/... file from the parameter tab.
It has now become a true PITA to search the whole .../data/... folder, in order to find one particular morph file.
Redacted
Locate them or edit them in an editor. You have to click your way through the folder hirachy tree if you know where to find it, when you're lucky.
It would be just better if you had a right click on the morph dial, the option to brwse to folder in order to find the refering .../data/*.dsf file.
I would like to see an icon or * in the title indicating if the scene has been altered to let one know if it needs to be saved or not. I have scenes that take up to 10 minutes to save sometimes and I don't know if It's good to alter or not. So I wind up resaving them several times. (Working in usually 6 instances at once, it gets confusing.)
BTW Master, check your email on the other site.
Redacted
