Super suite not fit genesis 2 actor when rendering !
muaboithu1001muaboithu1001 Posts: 0
edited September 2014 in Daz Studio Discussion
Hello ! That's my problem ! I dont know how can I fix, please help, thank you so much !
I had used fit suite to genesis and fit genesis to suite but not sold the problem for both female and male genesis 2 !
Post edited by muaboithu1001 on
  • MattymanxMattymanx Posts: 7,000
    in the scene tab, select the suit and then go to the options menu (upper left hand corner in your screen shot) and under Edit choose apply smoothing modifier
    Then in the parameters tab make sure the suit is set to colide with the figure.
    To be honest, the suit does not need that step but uses a displacement map to give it its appearence. Double check and see if the displacement map is loaded too. You can just reapply on of the inlcuded mat presets.
  • muaboithu1001muaboithu1001 Posts: 0
    Worked like a charm ! Thank you so much !! And I just only Apply smoothing modifier !
    But I have one more than questions, I hope you help me fix its ! I'm just a beginner :D
    .In pic 1 : After choose a male's pose for female and I placed a male's sword but it not placed correctly in her hand.
    .In pic 2 : Female's suite now be fit with male genesis but when I render some place on him exposed, please view my check mark.
    .In pic 3 : Another situation, I created the male's suite first but when i but him back, suite and genesis not fit together althought I try with Apply smoothing modifier ! But after render Its fit and have 2 dot in his shoulder, how can I remove it and fit suite and genesis together before render ?
    And how can I always perform this check "apply smoothing modifier" ? Thank you !
    1366 x 730 - 611K
    1366 x 729 - 416K
    1366 x 728 - 331K
