dForce Head Dress issue with hair
dForce MIddle Eastern Outfit for Genesis 8 Female(s)
The issue is with the head dress
While you can load other parts which work fine, the head dress keeps going into the hair. It does not matter what hair you apply. Genesis 8 hair, Genesis 3, third party.
This set does not work with Genesis 8.1 unless you force it to and then still the same issue with the head dress and hair.
I have tried just about everything I can think of
Changing parent, fit to, trying to adjust the head dress, nothing will work to cause it to lay down on the hair and not go rigth through.
If anyone had a clue how to fix that, I would be really greatful.
    I don't own this one yet. On the product page it does list morphs for the Head Dress - something there should help as the promo figure has hair.
  • I'm using the same hair as the promo. I have tired several other hair as well. Nothing. Really makes me not want to purchase anything else.
    Not having the hair it's a little hard to guess what might work. If the headcover can be loaded on its own and not "fit to" the figure, raise it a little higher than the figure ... add a dForce modifier to it [Simulation Pane], adjust what needs adjusting [for collisions etc.] and run a drape?
    Maybe "fit to" the hair, not the figure?
    There is a 30 day money back guarantee. If you can't get the headcover to work, you can ask for a refund [store credit usually happens pretty fast].
