Scene pane listing - what spot does the "X" mark?
Roman_K2Roman_K2 Posts: 1,273
I just noticed something in the Scene pane in D|S and I don't know what it represents. Clicking on an item on or near the arrow produces a little "X".
What's that for?
For what it's worth, I've placed a red circle around the "x" in the attached screenshot.
  • LeanaLeana Posts: 12,909
    IIRC that symbol tells you if that node can be selected by clicking on it in the viewport. When there's a x it's not selectable.
  • MelanieLMelanieL Posts: 7,791
    The x means that the item is not selectable in the viewport.
  • Roman_K2Roman_K2 Posts: 1,273
    Soooo... this would be for if you... don't want to include something when you are... doing some sort of global change or movement?
    Like a locking device, sort of??
  • 3DSaga3DSaga Posts: 718
    I like to use this feature when I don't want something to be highlighted (selected) in a scene when I'm making adjustments to other items in the scene. If I'm working on a character in a scene, it can be a bit distracting if the whole setting turns yellow. I'm sure there are far many better uses for this feature as well.
    Got it, thanks. Ha, there have been LOTS of times when the entire thing pane has "turned yellow", for me!
  • PhatmartinoPhatmartino Posts: 287
    edited May 2021
    I like to use this feature on things in the backgound once they are set up (or if I don't need to easily select them in the Viewport at the moment) so that I can click on any of those things in the Viewport in order to "Un-Select All" in the Scene Tab. Helps to avoid and/or alleviate the "Everything in the Scene Tab becomes inexplicably Selected for no apparent reason" problem that's been rampant (for me at least) in DS for a while now...
    Post edited by Phatmartino on
