Displacement map causes black lines
Hello,
Whenever I use displacement map on the skin I get this weird black lines (see attached).
These black lines appear only when the minimum displacement is set to negative (<0). If minimum displacement is set to <0, then everything works fine.
This black lines are actually the outlines of the displacement map itself (so they are not random).
I tried searching for an answer, but can't seem to find anyone with the same problem.
Could it possibly be connected to the fact that the displacement map is of lower resolution than the texture itself?
Thanks in advance!
  • felisfelis Posts: 6,018
    Is there a geoshell on the character?
  • awpheroawphero Posts: 0
    Yes there was. I turned the geoshell off and black lines disappeared. Looks like negative displacement conflicted with the geoshell.
    Thank you!
