No shadows
ueanyueany Posts: 0
edited December 1969 in Bryce Discussion
Hi,
as you can see in the pic there is a point light ... but it doesn't cast any shadows. What's the problem with this? Cast shadows is activated.
  • ueanyueany Posts: 0
    My fault cause sun shadows were too weak.
    Anyways, how can I change the forums nickname?
    Could be several things.
    Things to check first are: In the Sky Lab, check the sun tab to see that shadows are at 100.
    Check the ground plane (or terrain if you have on set as your ground) in the Material Lab so make sure it is set to receive shadows.
    These are the two most likely things it will be... Hope this helps.
    edited August 2014
    Are you asking how you can change your forum username?
    If so then send a PM to Richard Haseltine telling him what name you would like (and a couple of variants in case that one is taken) plus he will need a note of the email address you log in with.
    Post edited by Chohole on
