GeoBra - Geometry Shell Bra for G3/G8/G8.1
chris-2599934
Introducing the GeoBra for G3F, G8F & G8.1F, a bra so comfortable it's like a second skin! No wires, buckles, hooks or clips, in fact no geometry of its own at all.
This product uses Daz Studio's Geometry Shell feature to create a bra that can be safely worn under other clothes without requiring many resources or causing poke-through. It is intended to be used under sheer or semi-sheer tops to preserve your model's modesty.
The bra is available in two styles (lacy and plain) in both 1K and 4K resolutions, and in three colors - but you can set it to whatever color you like by changing the diffuse. Both Iray and 3Delight versions are included.
If you're looking for a bra to be worn on its own, as outerwear, this product is not for you. There are a ton of suitable products in the shop, and freebies by (amongst others) Wilmap and Beat578 that autofit nicely to more recent generations. But if your model is wearing a garment over her bra, you can get problems with poke-through if the bra has geometry of its own. This product is for that situation - it essentially paints a bra shape onto the model's skin, so it can be seen through a thin top, but doesn't actually poke through.
Here's an example of it in use:
And now in creepy Man-O-Vision:
Here's one of the icon files to give you a better view of the front. I hope the strapping looks plausible, such garments really aren't my area of expertise!
You can download it here: https://sharecg.com/v/97449/browse/21/DAZ-Studio/GeoBra
Promo Credits
White Top
Red Top
Oh wow it looks great, thank you, downloading now and rated.
Nice, thank you very much!
This is great - I totally need this! Thank you!
Super quick render to show how this is really useful!
Excellent !!
Question - Is there a tutorial for making/using geoshell? Found some for making whole skins, but clothing I can't find.
I didn't follow any particular tutorials, but a google search returns 300,000 hits so there should be something suitable out there.
It's not really all that complicated. When you select an object and create a geometry shell, it creates a "shell" around the selected object with the same geometry and surfaces. What I did to make these bras is apply an opacity map so that you only see a bra-shaped part of the shell. I drew the map in a graphics program (Paint Shop Pro) with the help of mCasual's mcjTailorsChalk script.
Tremendous idea, nicely executed! I can see this will be a useful addition to my library. Thank you for sharing.
Very nice, thank you!
Thankye muchly! Works really well, and aside from an error on my part, (producing an intrigueing vanishing torso) well done. there's just enough "lift" so it doesn't look paintrd on.
Now to figure out how to do a pair of panties......
8 )
Cheers
Only just noticed this post. Any "lift" you might get it coming solely from the shape of the underlying model, because the GeoBra really is effectively painted on. It's just that the genesis figures are intended (perhaps optimistically) to be used clothed, so out of the box they're shaped as if wearing underwear.
It would be quite possible to make a pair of panties using the same technique. I didn't bother, because in my experience ladies don't usually wear sheer or semi-sheer skirts and pants, but maybe I'm just not mixing with the right ladies?
"It would be quite possible to make a pair of panties using the same technique. I didn't bother, because in my experience ladies don't usually wear sheer or semi-sheer skirts and pants, but maybe I'm just not mixing with the right ladies?"
Some women wear very short skirts and dresses or pose in a "compromising" manner, so a bra/panty combo would be quite useful.
Somebody will be looking for this!
