Ridge Walk Mountains - 3D Environment [commercial]
FirstBastionFirstBastion Posts: 8,047
edited August 2014 in Daz PA Commercial Products
Ridge Walk Mountains - 3D Environment Available Now.
http://www.daz3d.com/ridge-walk-mountains
Includes the ridge walk, the surrounding mountain range, the rocks and rope bridge and sparse grass props. The wind flags are also included and have built in morphs to allow for some flutterring variabililty The overcast sky is the wysiwyg fog cameras F/X in DAZ Studio 4.6+ with 13 fog cameras included.
The Uber Environment 2 lightset used in the promos is also included.
  • FirstBastionFirstBastion Posts: 8,047
    A closer angle on the rope bridge.
    900 x 1170 - 279K
  • fixmypcmikefixmypcmike Posts: 19,682
    Beautiful work! I'd glossed over this until I saw this thread and took a closer look, definitely a must have.
  • XenomorphineXenomorphine Posts: 2,421
    Excellent work, as usual!
    Are the ropes, posts and flags optional props?
    Absolutely you can hide or remove the rope bridge traverse, and the posts and flags, and since they have different material zones you can hide some of the parts too. You can also potentially use them in other scenes since they are separate props. One quick note, the entire scene loads into DAZ Studio with the lightset, skydome, and fog cameras and all props loaded at once.
    Great to hear! Options like that allow for much greater diversity.
    To give a sense of scale of the scene, zero position origin point is at the middle flag.
    1024 x 553 - 98K
    Excellent. Bought this the other day, and I've been amusing myself trying out the different camera views. Those fog effects are great! :coolsmile:
    Thank you for the comments Spotted Kitty.
    Here's a render I did by adding one of my water planes into the scene and changing the fog parameters a bit which is very easy to do (select the camera and adjust parameters tab) and can result in some variety of looks. If you increase the StartFog distance value it thins out the fog effects.
    647 x 615 - 70K
    1000 x 540 - 356K
