Paper format view issue
JamahoneyJamahoney Posts: 1,791
edited August 2014 in Bryce Discussion
I'm used to having the 'Paper' view format (left image below), where you can select from several in a list on the fourth icon down (on the right of the Bryce view interface...etc.,). Problem is for some unknown reason I opened a file and the damn thing showed a different format (right image below - note the sky shows up, too).
Now, I've clicked this fouth icon by mistake in the past, and found I had to go through several tries before I got back to the 'paper' option I prefer (lack of Bryce experience, essentially). However, trying again to get back to the 'paper' format from the fouth icon...etc., this time, I just can't get back to 'paper' view. Any advice? Presuming it's a corrupt issue, will I lose all previously-saved Br 7.0 render files if I have to reinstall.
I'm probably missing some obvious option, so forgive my stupidity.
Cheers
Jay
Post edited by Jamahoney on
  • Dan WhitesideDan Whiteside Posts: 507
    Looks like you have OGL preview on. You turn it off by clicking and holding (for a couple of seconds) the cube icon above the Zoom icons at bottom right and selecting wireframe preview.
  • OroborosOroboros Posts: 326
    What Dan said.
    So much disappoint that you can't do shift-click animations with OGL options :(
  • JamahoneyJamahoney Posts: 1,791
    Aha, thank you, Dan (Oroboros, too) - that solved it. I must have inadvertently held the cube too long at one time where the switch took place. I hate when simply-fixed problems like this occur, and then my ignorance of Bryce comes to fore.
    Cheers, again ;)
    Jay
