Has anyone ported Hitomi from Genesis over to G2F using GenX2?
ModernWizard
Hi all -- I love Hitomi, but G2F is my base figure these days. Thus I wonder -- Has anyone ported Hitomi from Genesis over to G2F using GenX2? The product page indicates that the Genesis rigging [?] was modded specifically for Hitomi, so, if anyone did port her up to G2F, how does she bend? Also does she have custom expressions that can port as well?
And does MallenLane's store ever go on sale? ;)
--MW
Hitonmi had been in the Fast Grab at least once or twice in the past year as well as it was part of the 60% off Genesis sale earlier in the year. The annual PA half off sale is coming up so it will be on sale at some point during that sale.
Given the fact that Hitonmi uses a modified Genesis rig, I'm not sure how well GenX would transfer the morph.
Thanks for the reply, icprncss. Rats, I missed her in the 60% off sale. Oh well, I look forward to next month, when she will be half off...
--MW
Hitomi works fine on G2F. Here's what I did to make sure I got it all:
- Dial in Hitomi on the regular Genesis
- In GX2 set the source as Genesis
- Right click in GX2 > All > Zero Values
- Right click again All > Transfer OFF (I do this just to ensure a clean transfer)
- Right click yet again > All > Get Values From Figure in Scene
See screenshot for the transfer settings I used. From here, transferring any of Hitomi's other special dials are up to you.
Also, don't forget to dial in the Genesis shape for G2F, otherwise transferred figures look funny.
I used Outoftouch's Fiends Forever skin in the picture due to it's toon-like nature. Skins with human nostrils just look really funny on her since the original figure had none and the G2F version has very tiny holes still.
/edit
Added a shot of the parameters to show that the method used retains the separate dials for the breasts and also transfers the hidden JCMs.
Keep in mind that the base Hitomi skin uses her own custom UV mapping. So while GenX can help you port her shape over, you'll need to use other skin texture sets.
Vaskania -- thanks for this detailed info. She's adorable and DEFINITELY going on my wish list. I'm glad to know that she can work on G2F -- then I can port her up there and mix her with all the other morphs I have loaded onto that figure.
cwichura -- thanks for the reminder.
--MW
If you own either Victoria 5, or else Victoria 4 for Genesis 2 Female, it should be able to do a map transfer to convert Hitomi's textures to use with Genesis 2 Female.
