Animation Anti-blocks that won't work
Some of the anti blocks won't activate. What should I do to make them work again?
A little context in your question would be useful. What are you trying to do?
Well , when I first got the Genisis Alive they all worked. But now some of them won't do anything on the figure not even adding it on the figure. I don't know if I should uninstall then reinstall it.
Genesis, or Genesis 8? What kind of figure are you using it on?
Genesis 2
So you're trying to apply a block to a Genesis 2 figure. What happens if you create a new scene, put a Genesis 2 figure into it, select the Animate tab and drag that block into it?
The figure won't do anything with that chosen animation. I first noticed they wouldn't test ,you know hold over tab.
